Only had car 2 months any help would be greatly received
Thanks Simon
Top tip come MOT time, thanks TonyIf you're up to changing brake pipes yourself Si, I can make you some and post them to you. Oil temperature showing 17 deg. no where even close to hot enough. At that temp the eng. temp gauge wouldn't be showing normal operating temperature. That is the first prompt on an emission analyser for the tester to follow. It really makes my blood boil that these people can't be bothered to do the job properly.
If your car is a low mileage/use one I would run the fuel down below 1/4 before test time and put in some fuel system cleaner and yes I do recommend Forte, simply because it is very good. Also don't forget you can have your car tested up to 30 days before the old one expires so don't leave it till the last minute. And before someone says " But you lose 2weeks off your last test " ..... Really? It gives you the time to get things put right if required.Top tip come MOT time, thanks Tony![]()
Get it at Halfords type places Tony?If your car is a low mileage/use one I would run the fuel down below 1/4 before test time and put in some fuel system cleaner and yes I do recommend Forte, simply because it is very good. Also don't forget you can have your car tested up to 30 days before the old one expires so don't leave it till the last minute. And before someone says " But you lose 2weeks off your last test " ..... Really? It gives you the time to get things put right if required.
Hi Andy it's not the brake hose it's the copper pipe.@Siamanda can't help with the emmissions but I had the two flexible break pipe lines changed recently at a BMW main dealer, £29.59 each for parts plus fitting. £124.28 Inc VAT parts and labour to have them changed and a fluid change. Probably get it cheaper elsewhere but should be the max you'd pay.
HTH's?
Andy
Thanks TonyIf your car is a low mileage/use one I would run the fuel down below 1/4 before test time and put in some fuel system cleaner and yes I do recommend Forte, simply because it is very good. Also don't forget you can have your car tested up to 30 days before the old one expires so don't leave it till the last minute. And before someone says " But you lose 2weeks off your last test " ..... Really? It gives you the time to get things put right if required.
.......... Oil temperature showing 17 deg. no where even close to hot enough. .....Tony.
Got it, thanksNot too sure Andy, but you can get it on eBay. Search Forte Advanced Gas Treatment has a red cap. Expect to pay £12.95. with free delivery.
Ah right, apologiesHi Andy it's not the brake hose it's the copper pipe.
Thanks TonyI had our rear brake pies changed 2 years ago no and fluid change £137 not including the brake pipes as I supplied these..
I used the BMW brake pipes which are plastic coated and were £13 each so not really that expensive but if Tiny supplies them they will be cheaper.
Where are you based? just seen from the phone no. New Forest
Need to do as above put some engine cleaner in and the car needs a good run at higher revs and make sure it is good and hot next time it goes for the MOT.
As @t-tony says if you take the car in up to 30 days before the MOT is due you will get the MOT for 12 months from the date on the old certificate.
Hope you get sorted, there are a few here around the New Forest area, my parents used to live not far from you and looks like your nearest dealer is Ridgeway in Bournemouth.
