Exhaust surprise!!
TriumphZ3
My 1998 Z3 1.9 has had an amazing exhaust rattle since purchase; not the silencer as I swapped that as one of the first attempted cures. It sailed through MOT with no problems a few days after I bought it six months ago. I reckoned it was the internals of the CAT - a US recall but not UK - and on removing the CAT section found a welded plate hidden on top as if someone had already tried a fix. The exhaust is dated 1997 so presumably original. My mate - he knows these things, so he tells me - told me to remove the CAT internals completely as since these engines are so good, my car would pass MOT with nothing there at all, but he took the exhaust away to fix it and after three weeks returned it. AND it still rattled, very loudly, on startup or any kind of acceleration. However having read the threads about the after-market Euro 2 CATS failing emissions I didn't want to risk one of those and as I couldn't find a second-hand version anywhere either locally or online had to buy new and direct from BMW. Yes, it cost me almost 40% of the price of the car and they declined to take the old one as a trade-in due to the welded plate.
However: the car is now transformed and the formerly lack-lustre acceleration in first and second is vastly improved. I was never impressed with the drive experience before but now it's a real ticket-gatherer.
I suspected this was down to a blockage in the CAT - my mate (he knows things!) was going to cut open the plate and sort out the CAT internals but instead spun me a yarn about putting a device down inside the exhaust that expanded and pushed the internal material out of the way thereby stopping the rattling and removing any obstruction. b*******s; I know he never looked at it. As I had no further use for the exhaust, I decided to open it up today.
Here's the patch on top, out of sight from beneath. Under that...
Here's another!! Amazing. So: cut that one out and...
Nothing. Completely empty CAT. No internals, no trace of ever having been any, and nothing to account for the rattle. Nothing to account for the poor performance either, no blockages anywhere.
So: will anyone care to debate as to why a car with NO CAT will pass emissions, when from when I've read on here the cheap sub-£200 Euro-2 CATs won't pass UK emissions, and how the performance was inhibited very badly with the straight-through exhaust fitted but a proper BMW CAT has now transformed it? I'm stumped, but happy. And poorer.
If the lambda sensor is located after the missing cat, makes perfect sense.
The ecu had abnormal readings and tried to adjust to its emission settings.
so it never gave full power because emissions would be high.
Single sensor only, before the CAT. That's what makes it so strange to me.
I don't think the computer would sense that the cat was gutted if the Oxygen sensor is before the cat, it would just be a more free flowing exhaust, off course I am in the states and not UK so perhaps your computer is different?
I know we don't have the level of inspection that you have.
But, if its a 98 M44 it should have two sensors according to the diagram.. puzled... so is it an m43?
It's an M44 according to the spec I checked using the VIN number, but both the old exhaust that I removed - marked 1997 - and the complete new unit from BMW only have one sensor, pre-cat. I could expect anything from 25 years of previous owners but not BMW themselves, who supplied the exhaust based on the VIN at the local Dealership. The date on the spec sheet is June 1998.
Both exhausts are identical bar the newer has only one 'dimple', the other on the old exhaust being where the resonation damper was fitted so I don't know where it goes on the new one.
I don’t know about the z3 design of cat but on my ktm motorbike I took off the non cat mufflers and put back on the oem ones with cat, I could clearly see the cat section through the muffler end pipe, which is made up of very thin material in a sort of honey comb (actually more like that multi layer cardboard but in metal) ….it was pretty delicate and it would be easy to bang a hole through it for its (only) 100mm length. I guess this might be the case with this z3 cat.
In nz there are no checks on emissions so if you want more noise the cats are replaced with a straight pipe 😁
First time I see the schematics to differ from the actual product.
maybe someone with an M44 can chime in and enlighten us.
Its also a bit of an assumption that a post cat sensor is used for “adaptation“ (aka fine tuning) it may only be present to detect if the cat is stuffed or not?
If I go to realoem and look up my car (M44) that second sensor is in the picture but it's greyed out so can't be selected.
But if I switch from EUR to USA spec that second sensor is not greyed out and can be selected.
So maybe something to do with regions and uk cars don't have that sensor?
There's two exhausts in that picture. Won't there be visible connection holes/sockets in the pipe where sensors go?
Old beside new, both identical bar the angle of the short post-CAT pipe. Only one screw-in socket along the entire length, pre-CAT.
Build date is January 22nd 1998, NOT June (that's the date of registration. ) Been in UK since new, one owner before me.
Just in case anyone needs a plug to fill an O2 sensor hole, I have some.
January 98 UK spec has one. (and its called 1.8)
1897cc? According to my V5 anyway.
That says M43 engine? If mine is claimed as M44, what's the visual difference so I can check?
