Getrag 250G gearbox oil change
Smudgemanuk
Bicester, Oxford
2.8l TU pre-facelift z3
My 98 Z3 2.8's Getrag 250G is due for an oil change
Which oil should I put in?
BMW genuine?
MTF or ATF?
Viscosity?
Brand?
Any help would be much appreciated
Thanks Chris
Nothing to do with me, but others have used this lot before.
I would second contacting Opie Oils. They will supply what you need. Also make sure to remove the level/filler plug BEFORE you drain the old stuff. Same goes with the Diff.
And you don't need LSD oil for a Torsen diff.
