Hiya everyone, I've been having an issue with my hardtop which has excessive wind noise near the rear of the driver side window at 80+ kmh. The passenger side window is quiet. I've already tried the adjusting screw at the bottom of the door to tilt the window inwards, but the screw was already fully outwards (which then turns the window inwards). I also tried to move the screw from left to right, but the window had no movement in it at all. The screw for the front smaller window did actually tilt the window properly, but the rear does nothing.
not that it matters, but the car is a 99 facelift z3, with a hardtop from 01. Also worth noting that I spent an entire day trying to get the alignment of the hardtop height right, but the wind noise always stays. You can also just see that the driver side window is much more outwards then the passenger. Driver also leaks when washing the car (also with softtop). The wind noise is most noticeable with the hardtop, but it's also there with the softtop, although that gets pretty much drowned out with all the other noise.
Does anyone have any idea on how to fix this? Going on a road trip in a month and would really like to take the hardtop and not go deaf due to the wind noise
