Heated seat retrofit help
Bigwinn
Lincoln UK
Z4 3.0i
Evening
In the process of retrofitting heated prefacelift seats into a facelift car
Seats are in and moving electrically and not throwing any codes so all good so far. Relay and switches likewise
I have the electrical schematics so can figure out which wires will need to be spliced from the plug under each seat- no worries
BUT
I cant figure out the seat wiring, they are different to the Z4 heated
See photo- there are 4 or 5 wires leading to the pads, both the same on each seat- one set red/yellow and one set red- 4 wires from the connector which i am assuming are + and - to the pads?
Am I right to think that? Or is it + red/yellow and - red
Anyone had experience of this at all
Attached are the wiring diagrams I am using for ref
Cheers
Stuart
Proceed with caution. All is not as it seems.
I have recently fitted facelift seats to a pre-facelift car and had to sort this out. Use a multimeter to confirm the elements. Elements are 5 ohms by memory.
You'll likely find that the red/yellow wires are for one element and the red wires are for the other element. Not the logical red/yellow = positive and red = negative.
Sage advice thanks
spotted this on the old version of the forum
