I'm opening this up to the wider knowledge, as I'm about at the end of my tether.
When I bought the smurf (2.8, M52 engine) the coolant was never really getting up to temperature (hanging around the blue mark) so I installed a new thermostat and viscous clutch (which was sticking on). Whilst I was doing that, the thermostat housing got a crack in it, so I purchased another. I had a right job bleeding the system, with the temperature heading upwards, a stab of the throttle bringing down and heat to the vents. No heat to the vents, temperature heading up, stab of the throttle, heat to the vents, temperature down (to mid way). I finally managed to get it to stop this behaviour, and it stopped over heating.
The only issue at this point was a lack of heat to the vents at idle, but warm air coming back when above c.1500 RPM. Again this didn't seem right, but I lived with it for a while.
My theory was that there may have been an issue with either slipping belts or with the water pump. So last week I replaced both (which required the cooling system to be drained). To refill the system, I filled through the top hose, squeezing pipes as I went. I put everything back together and started the car. And the behaviour started again
. No heat to the vents, temperature heading up, stab of the throttle, heat to the vents, temperature down (to mid way). It seemed to stabilise this evening on my trip back from the train station, but was still getting odd behaviour with no heat to the vents at idle.
I asked @BMBabe to help me to bleed the system again. I asked her to hold the revs at c.2500 RPM while I opened the bleed valve. At first there was a bit of air came out, but then nothing but water. Still no heat to the vents at idle
I've just taken the car out and it seems to have done more harm than good. Again, no heat to the vents, temperature heading up, stab of the throttle, heat to the vents, temperature down (to mid way).
The only other concern is the white smoke from the exhaust - it's never lost coolant as such, so assume (hope, pray) that this isn't all being caused by a head gasket issue. I should say that the temp never got above 3/4 at any point in the above narrative.
Sorry for the long post. Can anyone offer any guidance?
. No heat to the vents, temperature heading up, stab of the throttle, heat to the vents, temperature down (to mid way). It seemed to stabilise this evening on my trip back from the train station, but was still getting odd behaviour with no heat to the vents at idle. I asked @BMBabe to help me to bleed the system again. I asked her to hold the revs at c.2500 RPM while I opened the bleed valve. At first there was a bit of air came out, but then nothing but water. Still no heat to the vents at idle
