How do you fit a hardtop fitting fit
Hi has any one got any info about how to fit a Hardtop fitting kit ?
If not to late buy the OME not the doggie aftermarket one from Fleabay
When you remove the surrounding trim where the brackets go you will see 3 holes
its straight forward as long as your holes line up
Make sure they go on the right side ie the one with the electrical terminals on the passenger side
On the passenger side I had to remove a bolt out of the soft top hood to get access to 1 blot
A 13mm and a 10mm ratchet spanners are a must
Thats great thanks, to be honest i bought a 1.9 a couple of years same colour as mine with a hard top and fitting kit for £600 took the hard top and kit off and sold the car £500 so it was a cheap hardtop , but its all stood in my garage for a couple of years
The brackets should fit fine mine where aftermarket of fleabay they needed a bit of filing
I had too loosen off all the bolts to get the back catches locked I then tighten them up.
I wish I got my hard top for a £100
