Hyper Flash Relay
Explain hyper flash, have you fitted led bulbs to the indicators?
yea but I wanna keep the led buds, just wanna know if the flasher relay would work?
You can use LED bulbs which are CAN compliant. They have higher resistance so don’t cause the hyper flash.
I don't think that will work in a Z3, no canbus system, old relay system, but happy to be proved wrong.
I agree with you. There is no CANBUS system in the Z3 but the CANBUS compliant LED bulbs prevent the hyperflash from happening with no need to modify the indicator relay.
My understanding is that it’s because of a higher resistance in the LED bulb circuit which mimics the resistance of a filament bulb.
I’ve tried a lot of bulbs…. 😁
OK I'll take your word for it. Never worked for me on my Z3 always got hyper flash with canbus compliant bulbs (and they weren't cheap ebay ones either) until I put the modified flasher unit in. 🤷‍♂️
@Nodzed you were right!
I shall now go and eat my hat :thumbsup:
