I read somewhere....
Antm72
South Yorkshire
Some one is running as set of AP Coilovers i just cannot remember who :banghead:
Looking at changing my current set up but maybe you can answer a few fitment questions it may be @gookah my memory is naff !!
Any help would be appreciated.
yes it is me
memory is pretty good from what I can see.
The only fitment issues I had, was needing 5mm spacers on the front to clear the coilover coils as they sit a lot lower than the original spring shelf which sits higher than the tyre.
need for spacers and size all depends on wheel offset and size though.
What offset and rim size do you run ?
I have 19mm original shock body to rim i can not space as im @et38 8.5 and its pretty flush.
Do you have shock body size and the dimention of the widest part of the spring?
How does the rear lower well ?
