Seems like heat is much lower than in the past. Not only in idle but also while driving or when circulating air internally.
Thermostat, water pump and heater control valve solenoid are ok (and even if failed microswitch in behind heater control dial would leave the valve open).
I will try to remove any air in the water system and reverse flush the heater core.
Any other intelligent ideas?
