Hi All,
This might be a familiar story, but here goes:
After a couple of years in storage our 1.9 now won't start:- it cranks and has spark (runs on easystart) but has no pressure at the fuel rail. Prior to be dry stored it ran and drove fine.
This isn't too much of a surprise as the fuel pump evidently isn't running, and so far I've found the following:
- The 5 fuses in the ECU box all get 12v with ign on (I think this meant the DME powers up ok)
- Fuse 18 in main underbonnet box has permanent 12v
- Fuse 13 gets 12v with ign on ( I think/guess/hope this means that the EWS is seeing the key and the DME is happy?)
The fuel pump relay does not click when ignition is switched on, but pin 30 has 12v and pin 86 has 12v with ign on. However, pin 85 (I think should be a DME switched earth) has 0v with ign off, but goes to +4.25v once ign on. I assume this is why the relay does not attempt to energise, but I'm at a total loss to understand why this positive voltage appears
(In addition, I'm fairly sure I also have a failed fuel pump as well - if I connect a jumper between pins 30 & 87 on the relay base you can't hear the pump run and there's no pressure at the rail).
Any thoughts or tips very much appreciated!!
Tom
Tom
