My old Z3 has been driven backwards
TR4man
South Cheshire
Z4 Coupe
Just because I'm nosy and bored, I thought I'd see if my old Z3 got through the MOT at the end of last month.
...it seemed to have failed and then was passed. Great news!
However, what is remarkable, is that it now has less mileage than when I sold it last April......
Whoops someone has been naughty :p
Some times cars get younger and younger with the age...:whistle:depends on what fuel you use...
I was following some sales sites for Z3 , few years ago and it was so funny to watch a black safire sold in Italy in the first week with 160 tkm, after 10 days with 130 tkm, next 10 days 110 tkm and then 98 tkm! He even don/t bother to change the pics! In Germany if you do that , you go to jail (, if you get cought).
Oops.
Did you log the mileage on your V5C when you sold the car? I always do, even if the cars going to the scrapper.
@EnthuZiaZT 10 ft forward and 10ft backwards... He is scared of the mileage increasing. :whistle:
Of course it could be a single honest mistake by the M.O.T. Tester and nothing more. If the mileage isn't corrected on the day it was tested then it has to go to the DVSA to be put right.
The latest M.O.T. certificate will list the previous 3-4 years mileages so I can't understand how this can go under the radar if people are vigilant.
Just checked mine, it appears that it wasn't tested for 5 years, July 2010 - August 2015
That's plausible Sean, it was early October when us guys saw it at Upton on that Sunday.
If you look at my old car W884TJU you will see that the mileage recorded at the time of last month's MOT was 131,183.
I advertised it for sale in April last year with a mileage of 135,000 miles. It sold two weeks later and bearing in mind it was my daily driver sometimes clocking up circa 700 miles a week, when the new owner picked it up it would have been at least 136,000 miles. If you are so interested, you can see a copy of the advert if you search my previous posts.
So that's a difference of at least 5,000 miles. However, that assumes that the new driver hasn't driven it at all in the following 8 months and put further mileage beyond the 136,000 miles it was sold with - which is extremely unlikely!
So long as he doesn't wind it back to more that was stated on the previous MOT in Jan 2015, no one will know...
Unless the previous owner is as nosy as me....
Just CYA.
I have a mileage discepancy on my zed MOT's. My MOT centre accidently added 10k onto my mileage about 3 years ago and I didn't notice until 12 months later when it came around to re MOTing but they said they couldn't do anything about so I have had to live with it.
Hopefully if I ever come to part with it the new owner will be able to see what went wrong afterall who adds 10k onto a cars mileage.!
My Old Z3 was a garage queen for years until I bought it in 2010:
2005 to 2006=2,807
2006 to 2007=2,805
2007 to 2008=1,296
2008 to 2009=198
2009 to 210=939
And then I piled the miles on.
  • Vehicle make BMW
  • Vehicle model Z3
  • Date first used 31 December 1998
  • Fuel type Petrol
  • Colour Blue
MOT history of this vehicle
  • Test date 24 July 2015
  • Expiry date 23 July 2016
  • Test Result Pass
  • Odometer reading 96,136 miles
  • MOT test number 3761 3500 5237
  • Test date 15 August 2014
  • Expiry date 17 August 2015
  • Test Result Pass
  • Odometer reading 91,521 miles
  • MOT test number 1977 4762 4247
  • Advisory notice item(s)
    Brake pipe slightly corroded (3.6.B.2c)
    Front Brake pad(s) wearing thin (3.5.1g)
    Rear brake disc worn, pitted or scored, but not seriously weakened (3.5.1i)
    Front Brake hose slightly deteriorated (3.6.B.4d)
    Nail in nearside front tyre
    advise rear tyres heavy worn inner edges
  • Test date 12 August 2014
  • Test Result Fail
  • Odometer reading 91,469 miles
  • MOT test number 6175 5402 4271
  • Reason(s) for failure
    Nearside Front Brake pipe inadequately clipped (3.6.B.1)
    Front Suspension arm ball joint dust cover excessively damaged so that it no longer prevents the ingress of dirt (2.4.G.2)
    Offside Front Lower Suspension arm ball joint dust cover excessively damaged so that it no longer prevents the ingress of dirt (2.4.G.2)
    Front brake disc worn, pitted or scored, but not seriously weakened (3.5.1i)
    Parking brake: parking brake efficiency only just met. It would appear that the braking system requires adjustment or repair. (3.7.B.7)
  • Test date 13 August 2013
  • Expiry date 17 August 2014
  • Test Result Pass
  • Odometer reading 84,648 miles
  • MOT test number 8198 5562 3209
  • Test date 16 August 2012
  • Expiry date 17 August 2013
  • Test Result Pass
  • Odometer reading 77,149 miles
  • MOT test number 3058 8912 2259
    only 80% of high level working
    both rear tyres wearing on inner edge
  • Test date 18 August 2011
  • Expiry date 17 August 2012
  • Test Result Pass
  • Odometer reading 65,617 miles
  • MOT test number 7597 5023 1218
    advise n/s/r also n/s/f flex brake hoses clips missing but held with tie clips
  • Test date 2 August 2010
  • Expiry date 1 August 2011
  • Test Result Pass
  • Odometer reading 53,861 miles
  • MOT test number 3935 2491 0248
    Centre Rear Exhaust has part of the system slightly deteriorated (7.1.1a)
    Nearside Rear coil spring corroded (2.4.C.1b)
    front brake discs worn.
    corrosion forming on steering and suspension components.
  • Test date 2 October 2009
  • Expiry date 1 October 2010
  • Test Result Pass
  • Odometer reading 52,922 miles
  • MOT test number 3007 2587 9201
    Nearside Front Lower Suspension arm rubber bush deteriorated but not resulting in excessive movement (2.4.G.2)
    Front brake disc slightly pitted (3.5.1h)
  • Test date 1 October 2009
  • Test Result Fail
  • MOT test number 9535 7417 9273
    Nearside Front Brake pipe excessively corroded (3.6.B.2c)
    Offside Front Brake pipe excessively corroded (3.6.B.2c)
    Nearside Rear Brake pipe excessively corroded (3.6.B.2c)
    Offside Rear Brake pipe excessively corroded (3.6.B.2c)
    Offside Rear coil spring fractured (2.4.C.1a)
    Rear brake disc slightly pitted (3.5.1h)
  • Test date 25 July 2008
  • Expiry date 25 July 2009
  • Test Result Pass
  • Odometer reading 52,724 miles
  • MOT test number 4207 1770 8275
    Nearside Front Brake pipe slightly corroded (3.6.B.2c)
    Offside Front Brake pipe slightly corroded (3.6.B.2c)
    Nearside Brake pipe slightly corroded (3.6.B.2c)
  • Test date 19 July 2007
  • Expiry date 25 July 2008
  • Test Result Pass
  • Odometer reading 51,428 miles
  • MOT test number 2911 6070 7236
    Nearside Rear Tyre worn close to the legal limit (4.1.E.1)
  • Test date 10 July 2006
  • Expiry date 25 July 2007
  • Test Result Pass
  • Odometer reading 48,623 miles
  • MOT test number 9926 6199 6151
    Offside Rear Tyre worn close to the legal limit (4.1.E.1)
  • Test date 26 July 2005
  • Expiry date 25 July 2006
  • Test Result Pass
  • Odometer reading 45,816 miles
  • MOT test number 3607 3730 5217
  • Test Result Fail
  • MOT test number 1641 7740 5256
    Exhaust system not adequately supported (7.1.1)
