Oil drain plug e86
Alan W
Bexley, Kent
Z4 Coupe E86 3.0 si
Car is a 2007 Z4 e86 Coupe 3.0L si manual
Going to do my first oil change on this car but before l start, A) is it a conventional sump plug? B) Does it have a washer that l have to replace when refitting? C) If the answer to B is yes, where can l get one apart from a dealer? D) having no dipstick, is the oil level sender part of the drain plug or seperate?
Just want to make sure l have everything and know of any issues before l start it
Thank you.. Alan
Brian4
East Anglian Crew
Near Grantham
Z3 3.0i Auto
@t-tony will help. Sump plug washer usually comes with the filter. Plug is either Allen key or spanner and level sender is a separate unit bolted in the side of the Sump.
mwpe
Camberley
No dipstick, another retrograde step in the name of progress. :mad:
Basingstoke
Z4 Coupe 3.0si
Do mine every few months now.
Yes there is a washer on the sump plug "copper" but they do vary long as it can compress. Its also a 17mm bolt head. Washer will come with the oil filter or should do.
Going by the amount of oil taken out the engine/ what the engine needs I put back in near that amount, say 5.5-6 litres and let it warm up.
Oil filters for BMW normally come all "O" rings and a sump plug washer. Sump plug nothing special.
Brian4
East Anglian Crew
Near Grantham
Z3 3.0i Auto
Some don't have temp gauges. My 335 has an oil temp gauge but does have a dipstick hiding at the back of the engine.
