On my way home . . . . .
. . . . this happened!
I hit a bird as was overtaking a car and it hit my mirror and knocked the glass off. :mad:
Bozzy
Long Eaton.
That was a stroke of bad of luck mate, that's the sort of thing would p***s me off :(.
On another note, your poor zed looks like it's been in a jungle rally stage :eek:.
Redline
Nuneaton
E89 20i msport
Bad luck.
Is that the original mirror Tony?
Driving home I noticed my drivers mirror was starting to drop off. Slowed down to about 10mph, reached out and just as I was getting hold of it it slipped through my fingers, dropped on the floor and bounced, rebounded up into the air still in one piece and then went under the rear wheel :mad:
The BMW part is something like £112 :(
Replacements off ebay don't seem to fit properly, use a different mount and are also prone to dropping off.
Bad luck.
I'm guessing it was the original one Ian, sadly Ill have to try a cheap aftermarket one for the time being. @Jjim was lucky not to loose his on the roof motor day at home. He notice his was loose and he removed it and I gave him some 3M double sided tape which came home from Florida (Walmart) and he refitted it. The sticky heated pad is still there so at least I can try just a stick on glass.
Redline
Nuneaton
E89 20i msport
Am sure I bought a large sheet of double sided stick on pad. Didn't use it in the end. I guess some heat resistant adhesive would be better. In fact, I have some I used to put the glass front on the oven when it popped off a couple of years ago. Would be ideal I would have thought. Forgotten I had that.
When I got home the backing was still toasty =)) Might be worth having a look in the morning as I was on the right hand side of the road?
hard top
Dutch Zeds
Netherlands
Driving down one of our narrow Dutch roads with parked cars on either side in my Merc, I met a city bus.
I had nowhere to go and it kept coming straight at me and took out my wing mirror.
I stopped further up the road and walked back to look for it, found it in bits.
No point in trying to claim from these people.
Went to the Merc stealer and crapped myself when I was told what a new one would cost.
Being the naughty boy that I am, I parked on the road just out side the entrance to our drill pipe yard, got the lad on the forklift to park up with his ass just not touching the car, promised him a couple of pints, told the boss that the lad had just knocked my mirror off by accident.
Result, boss sent me to the stealer to get it fixed .... :ymdevil:
Ianmc
New Forest
Z3 (M44)
My daughter would ask, "how is the bird?":whistle:
So, if you're thinking of picking a fight with a blackbirds, my advice will be don't or you could end up with some of these.:(
Don't know if they'll polish out, look a bit deep.:mad:.
Anyway. The new one is in place. I cleaned the face with brake cleaner and dried it (and warmed it) with my heat gun. Quickly stuck it on then got a piece of wood I'd wrapped in paper towel and some cable ties to let it stick well overnight.
Paul Rice
Doncaster
Z4 2.5 E89 23
Should put a sticker on the mirror Tony, stop it shattering!
I've got some carbon vinyl ................ ;)
Not your birthday today. Special occasion?=))=))
hard top
Dutch Zeds
Netherlands
Speaking of which, as a present, I was given a brand new mobile phone in its box with all the trimmings.
I cant get the bloody back off it to add the SIM Card and battery.
Think someone is taking the pish .... :mad:
