- Oct 26, 2014
- Model of Z
- Z4 coupe sport.
25mls into a quick run and the dashboard decided to imitate a Christmas tree.lol
Got home put the Delphi scanner on it and this was the result.
according to most on the net this almost always leads to ABS pump/module replacement. Also says BMW can supply new part at over a £1000 and fitting would push price to in the region of double. After cancelling faults the scanner wouldn’t read any part of the braking system.
So jacked the drvs side up removed wheel and wheel arch liner to get better access to the ABS pump/module. Numbered the 6lines up took pic and made drawing of unit with pipes attached. Found half a wooden broom handle and propped brake peddle (pressure on) against drvs seat, easy with elect seats to get the right pressure on the brake peddle. This I was told (by @t-tony ) would push the survo piston past the replenish port holding it there( till repaired one fitted) so as to isolate the reservour thus no need to lose all the very new fluid. Less messy, only a few drips from the pipes getting unit off.
Unit with cushioned bracket still attached removed through the wheel-well.
unit all ready to get boxed up sent away.
Car was parked in everyone’s way outside my lock up garage but was drivable back into garage (as long as the brake peddle prop stays in position) using handbrake.
Contacted ECU Repairs and they sent me DHL post label and pickup date. So it’s off tomorrow to be tested and repaired if poss. If no faults found there’s a charge for testing and post, if repairable £259-ish all in. At 140,000mls this unit if original has done its job. Now that’s what I call very reasonable.
Will let you all know what the outcome is.
RHA,ROY.
RHA,ROY.
