Parking brake shoe adjuster
You had your garden furniture chucked in the pool yet?
Graham's been round today and put it all inside the house Mike and put the wheelie bins in the Games room (garage). Plan for the worst and hope for the best. At least nothing will happen till after Sunday to spoil that anyway !:)
I can't visualise that Tony.
Sorry mate, you may need to drill out the washer which sits on the spring and also the hole in the back plate. Just replace the hold down pin with the nut and bolt. Just tighten it enough to put tension on the spring.
mrscalex
3rd Party Trader
Swindon & Swansea
Got ya. Thanks!
mrscalex
3rd Party Trader
Swindon & Swansea
Well that was one nasty b*stard of a job getting the old cable out. Access is awful under the heat shield at the lever end though that came out with moderate persuasion.
The hub end was awful. In the end I took the support plate off and drifted it out from the wheel side. That was very effective.
Stopped for lunch and hopefully all back together between showers this afternoon.
Will post some picks on my project thread.
They can be a Bugger Rob, but you did everything I would've done and got it done. Nearly every old Z's handbrake cables have the outers in half and that's where the problems start.
mrscalex
3rd Party Trader
Swindon & Swansea
Don't buy Pagid cables! Too much agro trimming both end mounts to fit.
For £4 more I would have had a BMW one but none in the country.
I used a step drill when I did mine, only took a minute each side. Did you tie some string to the inner end before you pulled it out through the floor?
mrscalex
3rd Party Trader
Swindon & Swansea
Put an angle grinder over it. It was 2.5mm wider than OEM. I measured it with a micrometer.
I like to do it that way round in case a BMW cable goes back in one day.
Not very likely Rob, how long has the original one lasted? A patterned part might not last as long as OEM but will likely outlast your custody of the car.;) Either way, another job off the list. All you need is some sunshine now . . . . . . . :whistle:
mrscalex
3rd Party Trader
Swindon & Swansea
Force of habit form restoring old Scalextric cars. I'd never modify the car to fit a repro part in case I or a future owner found an original part.
Anyway, all sorted now :)
