Pingu's M Roadster
Pingu
3rd Party Trader
I made it half way round until the indicators and brake lights gave up the ghost...
Pingu
3rd Party Trader
The indicator was found to be one side of the hazard relay was shorting out.
I had to replace the hazard relay, which wasn't cheap, but Schmiedmann were the best source of an OEM one...
BMW Part Number = 61 36 1 388 533
[edit] Plus 29p customs tax - and £6.65 FedEx admin fee :eek:
Pingu
3rd Party Trader
Things to do over winter...
Inspection2 Service
Rear end refresh
Clean and patch paint small areas of corrosion
Paint rear beam
Repair jacking points
LHR brake pipe - replace copper with Kunifer
Replace handbrake cables
Rear beam bushes
Rear arm bushes
Overhaul differential
Replace diff mounting bolts
Paint rear arms
Remove broken exhaust hanger bolt in rear beam
Clean and paint rear calipers and mounts
Pingu
3rd Party Trader
I've cleaned the rust off the diff, and the handbrake cable has arrived.
I'd done the diff before, but it was very rusty and lots flaked off. I'm waiting for the day when it becomes porous :eek: - that will be a very bad day.
I used Jenolite to try to neutralise the rust, but I'm going to give this stuff a try...
