Rear anti roll bar drop links.
Hi Zedonist. Yes I saw that when searching the forum.It doesn't give a clear enough view to determine how the support is fitted.
The obvious question therefore is when you re-fitted the ARB what orientation did you use for the supports, leaning inwards or outwards?
I fitted them in line with the upturn on the bracket that they sit in, you do need to make sure that you have both wheels on the floor when doing it so would suggest ramps.
That should say "both wheels on the floor" I'm guessing.
A happy new year to you Rich.:)
The trailing arm bracket has an up turn just align to this as per photo below:
