Rebody Rebody Dashboard
Pond
Spaldingski, Lincs
Z3 project
A full set of 'veglia' replica gauges, speedo, rev counter, clock, water temp, fuel, oil pressure and oil temp from John at ETB is around £1,000.
That includes three new sensors to fit to the block.
I wouldn't think their 250 gauges would be right for 507, but it's worth having a conversation with John to see if he can o something.
After all, his gauges are just generic ones with new dial faces stuck on, basically.
Duncodin
Pontrhydyrun - in Crow Valley
M44 FrankenZed
Well it's not a replica so wrong dials won't be a problem. Just wantnto look period. The only reason I'd want the etb 250 gauges is because they have leds for battery, main beam brake etc to avoid drilling holes for lights. But for a 1000 quid I won't bother.
Pingu
3rd Party Trader
I saw a Youtube short of a vacuum wrap on a 1983 M3 dashboard. It looked quite good.
I painted mine with satin black, then a satin lacquer.
Jezza
They do have all sorts of guage sets at much less than the 250 prices - full sets at around £500
Gauge Sets https://share.google/114eMXkCBRYu2blGW
Pond
Spaldingski, Lincs
Z3 project
Seems people usually paint their dashboards? Crinkle paint, or whatever it's called.
Anyone done vinyl?
If you do paint whatever you end up with, I have loads of unused black (and red) crinkle paint you can have for a small fee. I over-ordered by quite a bit!
Duncodin
M44 FrankenZed
I'm likely going to try vinyl on the flat top surface. Rest painted body colour as per beemers of the period.
Getting back to attaching it to the remainder of the z3 dash. I'd like to screw it on but don't want to screw through the vinyl. Thinking of sticking with tigerseal but once stuck I'd never get it off again ie to repair/replace vinyl if it starts lifting.
Pond
Spaldingski, Lincs
Z3 project
When I was looking to get my dashboard upholstered, everybody I spoke to said DO NOT use vinyl on a dashboard, as it gets damaged very quickly by UV and by being heated/cooled a lot.
Leather is OK, apparently, but obviously a lot more expensive.
I only painted mine because the complex curves were proving too tricky to upholster TBH. And that was coming from professionals.
Jezza
Actually this is not the case. Good quality vinyl is not much cheaper than leather. The cost is in the labour which is the same whichever material you choose.
Duncodin
M44 FrankenZed
I assumed you'd gone for paint because of the complex curves around the double binnacle.
My dash top is quite flat but I'd still like to be able to take it apart if it goes pear-shaped.
Duncodin
M44 FrankenZed
I will post 'actual' work in my build thread but just wanted to give you guys a feel for where I'm going.
First, let me remind you what a 507 dashboard looks like
With the Z3 windscreen at a totally different angle and all the gibbins behind the Z3 dash, it's not easy to make anything like a 507 dash in a Z3 - likely why nobody has done it yet.
On the other hand, it can never be a replica because the shape of the whole car is wrong with just an ever so slight 'nod' to the 507. So with that in mind I'm not going to make a replica dash either. I just want something that doesn't look like a Z3 dashboard.
Determined to keep the Z3 instrument cluster exactly where it is - changing only the overlay - I come up with something like this.
Ignore the centre console, that isn't even started - it's just an idea how to integrate the existing centre console to avoid having to hide all the under dash gibbins. But, if I do it I've got horizontal sliders for the heater controls in the old radio slot and gauges in the old round heater controls and other switches in their original position at the bottom.
Anyway - what do you guys reckon?
