- Dec 26, 2016
- Location
- Spaldingski, Lincs
- Model of Z
- 3 litre Z3 pretending to be Italian exotica. Two previous E89 Z4s.
I have a question for anyone who has fitted the ETB replica Veglia gauges to their car.
Did you run new wires from the speed sensor on the diff to the speedo speed signal input?
Or did you use the existing BMW wires either from the diff output (red/brown and brown/black earth), or the BMW cluster output (black/white) on connector X271?
I ask because I have a problem with my speedo. I used the black/white wire from the output speed signal on the BMW cluster PCB which worked fine until last week. Now the speedo has gone AWOL. I have re-wired the signal cable to the red/brown BMW input cable from the diff and earthed the other diff wire. This has made little difference; my speedo goes nuts every time the car moves!
The manufacturer is adamant it can't be a fault with the speedo; it must be my wiring is picking up 'noise' and causing the speedo to go nuts. I am not convinced but need to eliminate this before I send the unit back for diagnosis.
BTW I originally wired into input 3 (red and blue) on the speedo, not the yellow input 2. I have kept it on the red/blue with the new wire as this is correct for the type of signal. I think I should have originally wired into the yellow on the speedo (input 2) with the original wire, but it all worked absolutely fine.
Thanks.
Thanks.
), there are 9 pulses per tyre revolution, so Distance per pulse = Circumference / 9
