My suggestion if you can get in to it is as follows. Get an angle grinder with a very thin cutting disc ( about 2mm) cut a slot right across the screw head about 2-3mm deep. Now get a large flat blade screw driver, these days most have a hexagonal piece just below the handle and place in the slot you have made and turn it using a spanner on the hexagonal piece below the handle while applying pressure on the handle at the same time.HTH.
You can get torx screw extractors. You need to drill the hole on those screws deeper to allow the extractor more to bite into. Never used these but have used the bolt extraxtors and need to be careful as they are usually brittle.
Try slotting the head as Tony has said, alternatively you could drill it out with a drill the same diameter as the thread. As soon as the back pressure is off the back of the head you can screw the thread out with some pliers.
Thanks guys, I'll try creating a slot in it first, then look at the torx extractor. It's have to be next weekend now.
I'm a bit gutted as I've been meaning to do this fix for ages. I got a replacement hinge from eBay, with no play in it at all, for a great price. It was a dark green with a blue hue of some kind and had some surface rust and paint bubbling in one area. I got some Kurust and some BMW Graphite metallic (not my paint code, but close enough for the boot hinge!), prepped the metal, used the kurust and painted. Restored hinge pic attached. I think it came out OK.
I've always used a dremel also. It had never failed me but you have to be CAREFUL WHILE USING IT. One slip and you'll be creating new vocabulary. Frankie
I always use my draper stud extractor set, only £8, as per Brian just drill a hole about 5mm deep with a 3mm drill, use a slow speed,mthevotherthetheboth just screw the extractor in, it is left handed so will undo the bolt.
IF on a torx the inside is rounded, i've once been able to get it out with an "inbus" (Hexagon).
I've got a set of these that fit on to a socket-wrench. So you take the bit -make sure it is big enough: should just not really fit- , you need to hit it in with a hamer (that's why it grips later on)...then put the socket-wrench on it and out is comes (as you can put a lot of force on a socket wrench and still undo it gently)
Cheaper option is to drill it out, use a drill a size down from the screw thread, the heat generated may well looses the bolt any way. Then use a tap to chase out the thread.
Or take a dremel or hacksaw and cut a screwdriver slot across it if you have easy access and use a large screwdriver to remove. You've got options so go to it!! JIM
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
