That part number was for the ///M you will need to check on real oem that it’s the same for your model.
Your welcome mate. Was good to chat.Right, well still couldn't get handbrake cable from the hub so as Althulas said, undid from the handbrake, the outer sheath was worn anyway.
But, the whole rear end is out now.
View attachment 148193 View attachment 148195 View attachment 148197
Can't afford powder coating so went for RUST BUSTER epoxy mastic for the covering. Wish I'd applied this to the sills.
Just for info the 1.25 ltr starter packs cover 5 sq metres so should be enough to do all I need (I hope). Colour wise I've gone for Metallic aluminum just for something different.
And I took a drive to the 'Zedshed' to pick up these 18's from Lee.
Bit of light kerbing on the very edges and I thought was only going to be able to refurb professionally. But after a read up, seems this is well within my grasp with an alloy repair kit. May get them re powder coated one day. Dark satin bronze maybe? I may do a separate thread for the wheel repairs (depending how they turn out).
And thanks to @Lee at the Zedshed. Spent a good hour or two allowing me to download his Zed knowledge and showing/explaining many refurbs I thought were hard. So thanks again Lee for your kind offer of help when I need it.
Bought some bearing pullers to get the hubs off. My wheel bearings feel nice and smooth still so may leave these in.
Much degreasing, rust removal, treating and painting to be done so may post some in between pics.
I've really been enjoying doing this work as it has given me a sense of achievement and to learn new skills.
Yes thats right, I removed both trailing arms which is doable if you get a load of extensions on a socket and let a ring spanner bind against the body. The diff and the rear beam came out together but to be honest the bolts holding the diff to the beam which are on top, with a week or two's intermittent soaking with penetrating oil would have come undone with a ring spanner. Was a lot easier maneuvering just the beam and diff. The exhaust is hung on wire as you have to let it down a bit for the beam bush ends to clear the threaded studs from the body. Was still a bit of wiggling needed but managed this by myself, one jack and some supporting pieces of wood and of course some obligatory swearing!Great job mateYou’re taking the rear end off in bits to manoeuvre it around the exhaust which is being left in place, right? Prob the approach I’ll take when I get round to it
Epoxy is great stuff, I put Lechlar epoxy primer on my inner sills and it’s holding up really well
Hi cheers!Coming along nicely. Lots of cleaning there, that’s the crap bit but once all painted up it feels so good. I don’t see why you can’t add the mastic over the sills still as another layer of protection but your work should see you ok if a after winter take off sills and clean every year as maintenance.
Yep It'll have to be punched out, it's knackered anyway from slipping with grips so the outer sheath is broken now so once out I'll replace - I think the other side was replaced at some point.Your welcome mate. Was good to chat.
If you still have the handbrake cable stuck in the arm we cut the cable and pull it out. Once out we slid a punch through one of the wheel bolt holes and knock them out. Never had one stick using this method.
I used a combination of small punches to get that locking tab out the way, then just undo the nut I think it’s a 30mm. I don’t bother with them again I use thread lock and FT tightness. The shaft should just knock out then.Yes thats right, I removed both trailing arms which is doable if you get a load of extensions on a socket and let a ring spanner bind against the body. The diff and the rear beam came out together but to be honest the bolts holding the diff to the beam which are on top, with a week or two's intermittent soaking with penetrating oil would have come undone with a ring spanner. Was a lot easier maneuvering just the beam and diff. The exhaust is hung on wire as you have to let it down a bit for the beam bush ends to clear the threaded studs from the body. Was still a bit of wiggling needed but managed this by myself, one jack and some supporting pieces of wood and of course some obligatory swearing!
Hi cheers!
I used original Waxoyl undercoat which never really dries and is always tacky so probably not the best substrate to a rock hard epoxy resin to go onto, I reckon it wont bond and just crack. Could try an area I suppose and see how well it fares over time.
What's the method for getting the locking ring off the 30mm wheel hub bolt? Prize off and buy new locking rings?
Thanks in advance.....
Hindsight is sh*** sometimes.Oh I meant it as tongue in cheek on the mazza straps, sorry. I sound like a right miser!Cracking job Steve. I would just buy one of Mazza’s kits and be done with it.
Get yourself a wire wheel on a drill and clean up the diff. I was doing that today on another LSD.
After I acid etched my metal, I followed with etch primer than two pac epoxy paint, then seam sealered and added my top coats of paint after.,I used bilt hamber epoxy but will be getting some leachers as Dr Wong used in his build much cheaper.
Nice to be back in a plane I bet expensive hobby though.
I’m pretty sure Deox gel would take much, much longer than grinding + Hydrate80. It was weeks and weeks until I got through the deepest pitting. But it really does work and is really benign to good metal.I did just see Dr Wongs thread and saw an acid etch like DEOX gel. Does look like a much more thorough rust killer. The Hydrate 80 does have rust killer in it. Time will tell if my easier chosen method lasts. On the sills I did literally grind back most of the pitted stuff, losing some sill material and letting the Hydrate 80 work on any I'd missed. So I hope I put more prep into removing rust rather than let the gel do it's stuff or an acid etch. Next time I think I'd use the acid etch type stuff as time wise, it's probably the same.
FLying yeah - only need two things to go flying; Airspeed and Money.
Not getting much change from £220/hr hiring a commercially maintained club aircraft. (every 50 hrs needs £2-3,000 MOT). MOst clubs want you to stay current which means flying every 30-35 days minimum. Syndicate = £90 flat monthly fee then £76/hr wet, So 1st hr probably nearly the same but subsequent hours much cheaper. Plus of course the refundable cost of the aircraft share when you decide to leave. Nothing fancy or vintage just a 1976 Cessna 172M (4 seater). Ultra lights or microlights are much cheaper to run it's just I'm a big heavy chap and I'd never be able to take passengers if I had something cheaper. Just for reference a 4 seater piper warrior fully fueled, only has 30 stone left over, I'm 17.5 stone, so even in a 4 seater can still only take someone that is 12.5 stone max with the rear seats empty.
