Right then so! Finished the back end now apart from a couple of brake pipe clips, the spare wheel carrier and bleed the brakes. Bought a compressor brake bleeder that draws through from the reservoir by vacuum. Dunno how good these are and I did buy a cheap version but it didn't look any different from some more expensive ones. As long as it can create a seal then it should work.
Here's a pic or two of my rear end
, please shout out for any obvious howlers.
I have got two bits leftover and cant see them from REALOEM diagrams. - They look like some plastic clips went on the pointy bits - any thoughts?
Then onto the front, much less to do up here, already ordered the parts but didn't realise Monroe don't make springs for the front. The ones on there don't look too bad. The discs are newish. Gonna rebuild the brake calipers. I'd already Done the sill to the front wheel arch but need to sort out some underside scrapes that have gone through the underseal.
And can I take the cross member off, the bit with the orange sticker on?
Still surprised how good this car is underneath for 156,000 miles. I've refurbed 2 of the wheels I got from Lee which I'm quite pleased with.
Another question.
Lower Wishbones; I have polybushes for the two ends and one wishbone is recent, can you buy replacement centre bushes, the sticking up one, or do I have to get a new wishbone? In the image above you can see the wishbone on the RHS and it's the bush on the bottom right of the pic. Any knowledge would be helpful.
Wife away this weekend so bleed brakes which I've never done before.
STrip out front suspension,
Remove and treat rest of rusty bits on front of chassis and rear of front wheel well.
Another question.
