Hi,
Can someone please advise [or show with pix] a safe way to place a Z3 on 4 jack stands under the jack up points? Some people say it's common sense and such but this is my first time and I have not seen a clear and precise instruction on it. Please go into as much detail as possible for jacking the car. No need to discuss how I need to do the specific jobs mentioned here. I will be changing the Auto Trans oil soon so I will be starting the car while it is on the jacks! Safety first! Later, I will be changing all the shock absorbers.
I have a 2T trolley jack and 4 x 3T jack stands, level concrete garage floor. I also have ramps and the low profile ramp extensions.
Questions include:
1. Do I jack up the rear and then the front or can I do one side and then the other side?
2. Exactly where can I jack the car so I can place the stands under the jack areas?
3. It is OK and best practice to place the stands under the jack points right?
4. Do you place the stands at lowest height then progressively extend them up?
5. What secondary safety precautions do you take?
6. Is it OK to just jack up the front, or just jack up the back? {to work on the brake calipers for instance}
Thanks guys, and girls of course
Cooper
Questions include:
Cooper
