metal scraping sound
As you can see in the pic below... the rust around that centering piece is where it sticks most.... Try a wire brush or a scraper to remove the contamination around there and a few good smacks with the hammer...
@Southernboy thanks for the tips. Didn't even think about using wd40 on that but to ease up some rust. Will be sure to give it a go
When the Mrs turned up with a terrible grinding sound it was just a stone stuck between the Disc and that steel shroud at the back. Bent that shroud back by hand and out dropped the stone. Just a thought.
I agree with that! Seems strange, but it hapend to me three times with different cars! Worth to check it!
@Woodsta888 I thought that but when I had a check there wasn't anything stuck in there.
Small update, haven't had time to get to the garage but I'm hoping tonight is the night I be metal scraping free wooo
Ok so at it again and iv pretty much tried everything. Pretty close to taking the hammer to the back of the disk. Still no joy getting it off. It's solid on but freely rotates making that nasty scraping sound
The "laser" is always the final solution.
Well done. Now you can finally sort the brakes out.... You do know you'll have to do the other wheel too...;)
Dont forget the copper grease on that joint when you put it back together.
Watching a garage mech the other day and they put one wheel bolt back in loosely and hit the front face of the disc with a BIG hammer and came off. The bolt was just to stop the disc flying off and hitting you/anything. The discs were probably ruined after but they were worn out.
Wooooo effing got it
Derek, I hope you realise this makes you an expert on rear hubs now, we'll all know where to come...=))
Well don't come to me with a Volvo XC 90 with parking brake issues. What a piece of CARP. They were one of the first to use this idea and now they have totally f***ed it up. Why can't they leave things alone?
Yoiks Tony, must've struck an angry nerve here:rage:. Never had (nor likely to have) a Volvo XC 90....thank gooodness;)
I hate to admit it but I had to resort to Googling the bloody thing to find out how they adjust Dave. Embarrassing.;)
Yeah, knew you would in the end Derek. Hope you can sort out the fault more easily now. If you have questions just ask.
...I had to resort to Googling the bloody thing to find out how they adjust Dave...
Don't do yourself down mate, you were just 'using all the tools available to you':D
