Anyone running Uniroyal Rainsport 3 tyres on their Z3 (or Z4)?
I gave these Uniroyal's a thought recently before I replaced my rear tyres.
But these are aysemetric so you can't turn them round on the rim to help even out the uneven wear,re how the rears wear faster on the inside edge.
The Hankooks I bought for mine have a traditional tread pattern so can be turned on the rim,which means a longer tyre life,which matters to me as the zed has covered 20k miles in just under 2 years.
But if you're not doing loads of miles it won't concern you I guess.
Steve
I used to do this with the old Falken 452's. Doubled my rear tyre life from 6k to a nearly 12k miles!I gave these Uniroyal's a thought recently before I replaced my rear tyres.
Steve
Good point Dino.I used to do this with the old Falken 452's. Doubled my rear tyre life from 6k to a nearly 12k miles!
You need to check if a tyre has an 'outside' marker too - if it does then you cannot so the side to side swap as you want the outside of the tyre to be on the inside when swapped. I found this out with my Nexen N8000 - they look like you can swap but as it has those markers I cannot.
