Hi Guys.
I was hoping there might be someone with a little elec-trickery knowledge out there.
So i am planning on putting some Nissan seats in the Z.
My original seats are electric, up / down backwards/forwards, no heating
The seats that i plan to put in are the same.
The original wiring has power in the form of one connector with 2 wires, positive and negative i assume.
The new seat has one connector but the connecting plug has 4 pins and 4 wires. At a guess i would say this is 2 wires for each motor??
The other connector again i assuming is for the air bag which i obviously wont be connecting.
How can i check which is positive and minus of the pins. I was sure there is a way of testing resistance or something with a multimeter, and the resistance will tell you which is positive?
If all my vague assumptions are correct i am again assuming i can split the feed from the original wiring
Any ideas
Thanks
Any ideas
Thanks
