I've been planning to do this service for a while. Ever since the clutch slave cylinder exploded I knew I'd have to do the clutch...which follows with a whole lot of "while your in there" type of things.
1. Clutch
2. Rear-main seal
3. Pilot bearing
4. Oil pan gasket
5. Oil pump nut modificatino
6. Transmission input shaft seal
7. New fork, throw-out bearing.
8. Shifter detent service
9. Shifter bushings plus a duel sheer selector rod upgrade.
10. Drive shaft flex disc
Lets get to it. A buddy let me put the car up in his barn. He also has an S52 car. It needs a bit of love.
The first thing to do was remove the entire exhaust, heat shield and the X brace under the engine. Then I disconnected the drive-shaft.
The next step was to completely forget about taking pictures and focus on remvoing the transmission. It took some time to figure out but the key is pitching the engine&transmission backwards and using really long extensions. This seems to be the best way to disconnect the bell housing from the engine.
First off, the rattling noise inside the transmission was the piston from the exploded slave cylinder. It was way bigger than I thought it was. There were many metal bits to clean out. I put it next to a 10mm socket for context.
As for the damage it caused...some yes. Look how beat up the back of the pressure plate was.
The other victim here were some of the support fins. Two of them got pretty chewed up. Look past the spline shaft.
From here I decided to pretend that everything would be fine and continued. First things first. Shifter detents. This service, while a bit intimidating at first, was really not that bad at all.
I forgot to take pictures, but after this I put a new fork, pivot pin, throw-out bearing, input seal and cover to the inside of the bell housing.
Then I removed the clutch assembly. It was here that I decided to order a new flywheel.
Definitely some interesting wear happening here. The clutch itself was toast as well.
Still more dissassebly to go. I should mention just how slimy and grimy the oil pan and transmission were. The oil pan gasket had failed some time ago and the under side of the car was absolutely filthy. I spent quite a bit of time cleaning. Anyway, I had to brace the engine so it wouldn't fall on me while I removed the front subframe crossmember in order to gain enough clearance to pull the oil pan.
A bunch of bolts later and it's off! This is after I cleaned it up, but overall not too bad! No scary sparkles or anything too concerning.
I bought a wire nut to replace the existing oil nut sprocket. Apparently they can walk off randomly. Seemed like good insurance so I replaced the nut and tied it to one of the arms of the sprocket. All of this is off picture because I'm a terrible photographer.
Yep...25cm to the right and you would see it. Oh well. You can see how bad the original gasket was. Most of it is still sticking to the engine in this picture. I had to spend a good amount of time cleaning this up being careful not to gauge the aluminium.
I started working my way backwards from here. I put the new pan back in, along with a new seal for the oil dipstick. That's an important bit. Then I went to the rear of the engine. This part was awesome. I used a few slices of bread to push out the pilot bearing. Cleaned up as it went! I can't believe how well this worked. Push bread into the center and keep hammering it in with a socket extension. Keep adding bread until it begins to push the bearing out. Worked so well. So, new bearing, rear main seal and gasket. Done.
After that I added the new clutch assembly and flywheel. All new hardware used.
Moving back to the transmission itself. I decided I would do as much of the shifter linkage outsdie the car as I could to make life easier for me. Look at the difference before and after the new shifter rod coupler is. I don't remember what it's called. The bushing inside it was completely gone.
Do you have a vibration when you accelerate? Check out your drive shaft flex disc/guibo. Cracks are bad. Here's the one I replaced.
I guess this is where I apologize and got so excited I stopped taking pictures. Everything went back together fairly smoothly. I installed the DSSR as the only real upgrade to the shifter pushings other than a poly pivot (point? bushing? whatever.)
Let me tell you the combination of the new detents, bushings and the dssr have made a WORLD of difference. I have to learn how to drive the car again. The clutch engagement feels about the same, but I should probably adjust it a bit since it catches near the end of the clutch pedal travel.
Everything feels tightened up. Very happy with this and glad I have it out of the way. Also happy to report no fluids have escaped the new gaskets as far as I can tell.
