I seem to think about one and a half litres Baz
Having a coffee waiting for the diff. to drain , quite a bit came out of the filler plug ?
You didn't stand the bottles of oil in hot water beforehand then?
) .75w 80 synthetic gear oil, https://www.opieoils.co.uk/p-1019-r...al-transmission-lubricant-mtl-75w-80-gl4.aspx
takes a bottle and a half so order two.
Thanks Tony, just confirming: is this for a Getrag manual?Drain plug on the bottom, filler plug drivers side of gearbox. Ensure you can undo the filler plug first before draining. The plugs are a taper fit so have no sealing washers, you need a hex key on a socket wrench to undo them.
The Diff plugs do have alloy sealing washers, best to have a new pair to hand, the originals will have corroded by now and resemble lace.
